These articles from Lexmark might help:
Communication Issues with USB
http://support.lexmark.com/cgi-perl/...ame=&docid=845
Shortened URL:
http://tinyurl.com/lxa3
USB Printer Is Not Working
http://support.lexmark.com/cgi-perl/...&docid=ENUS171
Shortened URL:
http://tinyurl.com/ou0z
How to update the USB device driver for the printer
http://support.lexmark.com/cgi-perl/...ame=&docid=879
Short URL:
http://tinyurl.com/ofyk
PattyL
"capate" <> wrote in message
news: om...
> Hi
> I have just installed a lexmark x5150 (usb) printer on a friends computer.
> The installation seemed clean (no errors), test page printed fine and
> printing from applications initially seemed fine.
> However, this has now turned into a intermittent print problem.
> When it *doesnt* print, there is no evidence of anything different
happening
> on the computer side (no error message etc), the print dialogue box comes
> up, then the lexmark popup window with the progress bar, "printing
started"
> audio, printer icon comes up on taskbar, progress bar moves to 100%,
> "printing complete" audio, task bar printer icon disappears. There's no
> error message on printer control panel and NO printed output. The computer
> doesnt freeze or lock and you can continue as if nothing has happened.
> When it *does* print, exactly the same as above, but when the progress bar
> get to around 10% the printer kicks in.
> A reboot of the system solves the problem until the next time it chooses
not
> to print.
> Im presuming that its a usb problem (sleep mode?) Does anyone have any
> ideas?
> Thanks
> Steve
