Printer Forums
Printer Forums - Printing Help and Support > Newsgroups > Printer Newsgroups > Windows 98 Printing > Local RAW Print problem
Reply
Thread Tools Display Modes
fcosta
Guest
Posts: n/a
      09-05-2006, 07:24 PM
I developed a program that print directly to a dot matrix printer using
RAW mode. Itīs work fine in Windows 2k/Xp, but on Windows 98 it does
not work. If I have 2 win98 lan machines, I can print from remote host,
but I cannot print from the computer in wich printer is installed
(local port LPT1).
I tested disabling spooler, but didnīt work.
Any suggestions?
Jeff Richards
Guest
Posts: n/a
      09-08-2006, 09:37 PM
You will need to describe the problem. Does it produce no printout at all,
or is the printout wrong in some way or is there an error message or what?
Jeff Richards
MS MVP (Windows - Shell/User)
"fcosta" <> wrote in message
news: oups.com...
(local port LPT1).
Any suggestions?
fcosta
Guest
Posts: n/a
      09-30-2006, 10:35 PM
There's no printout at all. But to my program, it's happen as if all
worked fine. No error were reported.
The print failed only at the machine where the printer is physically
connected (LPT1). If I print by a remote host, the print work fine. And
it's only occur in dot matrix reports.
> Jeff Richards
> news: oups.com...
> (local port LPT1).
> Any suggestions?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Print Problem NoWay Windows ME Printing 0 01-22-2006 04:52 PM
network print problem gz Windows 98 Printing 1 12-31-2004 09:24 AM
lexmark x5150 (usb) - intermittent print problem capate Lexmark 1 01-22-2004 12:49 AM
Unable to Print to 2000pro using ICS Chu Rey Windows 98 Printing 0 10-28-2003 05:17 PM
Re: local printer fail but network print is fine. PattyL Windows 98 Printing 0 08-05-2003 12:03 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
