Print Migrator does not restore add on software from the vendor. You need
to install this on the new machine. Sometimes the only way the vendor
provides an installation path is with the driver install. Once you
reinstall the software stop and start the spooler service.
> HP Standard TCP/IP Port
> HP Universal Print Monitor
you will have to check the registry for these. I know Epson has a print
processor that goes into the \prnproc\w32x86\3 directory (the default
location is prnproc\w32x86)
> Print Processors (20)
you should see an Error event 24 when the port for the printer does not
exist
Printer NUL failed to initialize its ports. Win32 error code: 1796 (0x704)
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
This posting is provided "AS IS" with no warranties, and confers no rights.
"dtnguyen" <> wrote in message
news:2743E2C0-605B-4D06-BD41-...
> Hi Alan,
> Thanks a lot for your respond. However, it would be great if you can give
> me
> more details of the solution.
> Here is a little more details about the issue I have:
> On the older print server I have:
> Printer (531)
> Printer Drivers (149)
> Printer Porst (488)
> Print Monitors (5)
> *Print Monitors included:
> Local Port
> LPR Port
> New Print Server (after restored using Print Migrator 3.1 tool)
> Printer (528)
> Printer Ports (462)
> Print Processors (19)
> Print Monitors (3)
> *Local Port
> *LPR Port
> *Standard TCP/IP Port
> As you can see, Printer Drivers is the only one succesfully restored. I
> don't see any error on the System Event log.
> Am I missing anything?
> dtNguyen
> "Alan Morris [MSFT]" wrote:
>> Print migrator will not migrate 3rd party port monitors. Reinstall the
>> Port
>> monitor
>> Print Migrator will not migrate printer drivers that use a cab file.
>> Reinstall the printer driver
>> Look for the eventlog entries when the spooler was started for a list of
>> printer drivers that did not migrate.
>> After you have installed the 3rd party port monitors and drivers that use
>> cab files, stop the spooler service and restart.
>> Look for any event log errors
>> Alan Morris
>> rights.
>> news:16A80E94-AA79-4D3D-ADEB-...
>> > Hi all -
>> > I'm trying to migrate our old print server over to the new print server
>> > I ran the Print Migrator to backup all print queues, drivers,
>> > ports,etc...on
>> > the old print server, and ran the restore to the new print server.
>> > After
>> > the
>> > restored. I notice that a few print queues, Printer ports, Print
>> > Processors,
>> > and print monitor are missing. Checked on the pm.log, didn't find
>> > anything.
>> > The old print server running Windows 2000 with SP4. The new print
>> > server
>> > is
>> > Windows 2003 R2 Standard 32 bits with SP1.
>> > I don't know if I missed anything during the backup and restore using
>> > Print
>> > Migrator 3.1 tool.
>> > I would really appreciate all of the help from the experts out there.
>> > dtNguyen
