Hi, I'm new here and I hope to fix my issue in my Epson printer.
I use rechargeable cartridges.
The issue is that cyan color doesn't work.
I tried to make a lot..a lot...heading cleanings and i drained at least one charge for each cartridge.
Then I tried to use alcohol, and then ammonia through a syringe on the cyan nozzle directly but i still have the same problem.
I tried to use a cloth soaked with ammonia rubbing between headings and nozzles. Then I tried the alcohol through this method but i didn't fix my issue.
Sometimes when i printed the headings test page I rarely have found some trace of cyan color but only some trace.
Do you how can I solve my annoying trouble.
Thank you for reading..
