Error 2102
Hi
Have changed my xp to a win7 and scaning to a folder in a 1118 mfp task doesn't work keeps giving error 2102
Can anyone help me?
Thanks
Hi
2101, 2102, 2103, 2201, 2202, 2203,
3101: The network cable is
disconnected or the hub that it is
connected to is not operating
properly. Check the cable and the
hub. Otherwise, the server name or
the host name of the SMTP server is
not set correctly. Use COMMAND
CENTER and register the SMTP
server name and the host name
correctly.
Perhaps the shared folder rights need to be looked at
