I bought a new duplex laser printer M2625D from Samsung.
I works fine except one thing:
I want to permanently adjust some initial printing properties (under 64bit Win7):
- Set duplexmode = on = flip at the long edge
- print 2 on 1 (print two digital pages on one physical paper)
So I went to the printer properties as you can see in the following snapshots and set
e.g. duplex=long edge
http://www.picfront.org/d/9mdH
then I returned to the calling program (editer, pdf viewer, Word,....) and printed the stuff successfully.
However the next time I want to print again something I have manually to re-adjust all the settings.
This is annoying.
I though if "Last used settings" is the top-most on "Favorites" tab then the last printing properties will be automatically remembered.
Unfortuantely this is not the case.
None-duplex and 1-on-1 is set as initial printing mode
How can I tell the printer spooler to set the properties PERMANENTLY?
Thank you
Peter
This is annoying.
Thank you
Peter
