Hello, our office would like to connect our Brother printer to our local network using Ethernet.
I've read the Quick Start Setup Guide and they want you to install MFL-Pro Suite software on your workstation. The problem is we're not going to install software on every workstation in the office just to get Ethernet to work.
Does anybody know how to enable Ethernet at the printer ? I've tried to do this, but "Wired status" always says "Wired OFF". The cable is connected but there is no activity on the Ethernet switch box indicators. There's got to be an easy way since every computer in the office has Ethernet capability built in.
Thank you.
Thank you.
