Printer Forums
Printer Forums - Printing Help and Support > Newsgroups > Printer Newsgroups > Windows Vista Printing > Using fax in small home network
Reply
Thread Tools Display Modes
Pedro at DLA
Guest
Posts: n/a
      01-08-2009, 10:38 PM
Hullo. We have four or so computers on a home office network, with one of
them being used as a fax receiver, using the fax software that comes with
Windows. We want to be able to send faxes from each computer, via that one
that is connected to the phone line. It has XP, most of the others have
Vista.
Can anyone help?
Cheers,
Pedro, Canberra, Australia
Russ Valentine [MVP-Outlook]
Guest
Posts: n/a
      01-08-2009, 11:55 PM
It is not possible to share any of the Microsoft Fax end user client
software. Never has been. Never will be.
Russ Valentine
[MVP-Outlook]
"Pedro at DLA" <> wrote in message
news:BFCA35B7-80EF-4372-81C2-...
> Vista.
> Can anyone help?
> Cheers,
Pedro at DLA
Guest
Posts: n/a
      01-09-2009, 12:15 AM
Thanks Russ.
Do you know of a simple inexpensive program that will do it? (Simple as in
easy to use?)
> Russ Valentine
> [MVP-Outlook]
> > Vista.
> > Can anyone help?
> > Cheers,
Guest
Posts: n/a
      01-09-2009, 12:51 AM
No, because I haven't the time to stray beyond Microsoft's offers. Hopefully
others here might.
Russ Valentine
[MVP-Outlook]
news:3618A879-ED6D-409B-A185-...
> Thanks Russ.
> easy to use?)
>> Russ Valentine
>> [MVP-Outlook]
>> > of
>> > with
>> > one
>> > Vista.
>> > Can anyone help?
>> > Cheers,
Mike Hall - MVP
Guest
Posts: n/a
      01-09-2009, 01:50 PM
> Vista.
> Can anyone help?
> Cheers,
As far as I am aware, each computer would have to have an analogue modem
installed, and then each machine would go into conflict with the others
regarding receiving a fax..
Look into buying a cheap fax machine..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default...help&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
LVTravel
Guest
Posts: n/a
      01-09-2009, 01:57 PM
"Mike Hall - MVP" <mikehall@remove_mvps.com> wrote in message
news:...
>> one
>> Vista.
>> Can anyone help?
>> Cheers,
> Mike Hall - MVP
Mike, just to let you know that you can turn off the fax receive capability
of any of the Microsoft Fax programs so there would be no conflict if each
machine is set to transmit fax but only one set to receive.
LVTravel
Guest
Posts: n/a
      01-09-2009, 01:59 PM
> Vista.
> Can anyone help?
> Cheers,
Don't believe it can be done with MS products. Google for what you want.
Another way would be to purchase a multifunction, network capable printer
that has fax capability.
Chuck
Guest
Posts: n/a
      01-19-2009, 04:26 AM
Some of the Brother network multifunctions have the capability, and come
with basic fax software. I don't know if the software is Vista compatable,
since the unit I was using was used with XP. My laptop using Vista Ultimate
did recognize the scanner and printer parts of the multifunction via an
ethernet connection.
> Vista.
> Can anyone help?
> Cheers,
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Laptop no longer connects to printer on home network Moose95 Windows Vista Printing 16 12-14-2008 04:03 PM
Network Problem - Vista Home Premium and HP OfficeJet G85 Bill Hewlett Packard 0 01-24-2008 04:20 AM
Windows Vista laptop can't connect to network printer on home netw johnels Windows Vista Printing 5 03-16-2007 11:14 PM
can't print to windows 98 machine being used as print server attached with USB port from XP machine on my home network SteveSanders Windows 98 Printing 1 06-05-2004 10:19 AM
can't print to windows 98 machine being used as print server attached with USB port from XP machine on my home network SteveSanders Windows 98 Printing 1 06-04-2004 10:20 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
