Call (800) 646-6816 for Help: YouTube TV Local Channels Not Working
Call (800) 646-6816 quick assistant, Considering it might be the main avenue for regional programming, news, and sports, there is nothing as disappointing as problems with local channels on YouTube TV. Assuming your YouTube TV local channels aren't working, here are the major reasons and solutions.
1. Home Area Settings
This is normally due to how the home area has been set up for your YouTube TV account. YouTube TV normally bases local broadcast availability on your set home area. If you have moved and haven't updated that setting, or changed something on your device, that may be the reason you can't get local channels. For a solution, make sure the home area is correctly set in your account settings.
2. Mobile Device Issues
In some cases, an issue with the playback of local channels on mobile devices may simply be related to the location service for that device. Ensure that location permissions are turned on for the YouTube TV app on your phone. Check your device settings to ensure location services are on and set correctly.
3. Switch Locations
The problem could be that you have traveled or used your account in a different region; hence, YouTube TV cannot easily change local channels. Actually, this is a service restriction to make sure that at any given time, you access content relevant to your current physical location. To troubleshoot this, sign out and back in or restart the app to refresh your location data.
4. Troubleshooting Steps
Check that the internet connection is stable.
Make sure your location settings within your streaming device are up-to-date.
If none of the above steps work, reach out to YouTube TV support at (800) 646-6816 for further assistance.
Knowing how to refresh your home area or current location setting reduces the likelihood of local channel interruptions.
