Hello,
I have a Canon MF 8180c printer that worked perfect untill 2-3days ago now for some reason it refuses to get an IP adress...
When i try to install the printer with the canon install utility i select network printer it finds it but in the ip adress field it says "ip not set" now i have tryed to setup the ip manually and automatically using dhcp but nothing seems to work...
Does anyone know a fix i can try to make the printer be working again ? a hard reset or something?
Thank you for your time.
