Epson Premium Glossy A4 - curling from new - feed problems
Discussion in 'Epson' started by Si, Feb 22, 2005.
  1. Si
    Si Guest
    I've purchased several packs of Epson Premium Glossy A4 now and each sheet
    of paper seems to want to curl up as soon as you remove it from the pack...
    It's not bending crazily, but just enough so that my R200 doesn't want to
    take up sheet unless I curl the paper in the opposite direction...
    Anyone else found the same?
    Si.
    Si, Feb 22, 2005
    #1
    1. Advertisements
  2. Si
    Kevin Guest
    No. I have never had this problem with any make of Premium Glossy Photo
    Paper, Epson or otherwise. This sounds like an environmental issue like
    extremely high humidity or even wet (moist) paper.
    Kevin, Feb 22, 2005
    #2
    1. Advertisements
