Hello,
I am new to the forum. I want to ask that if I can print adhesive/glue from an inkjet printer?
If yes then what kind of adhesive will I be needing? water-based, solvent or something else?
Also would not it clog the print head?
Here are some videos that print adhesive from printer
Or if it is some other material they are using, kindly help me.
Thank you
Thank you
