Hp pro200 laserjet
sir,
i have one hp pro 200 laser jet printer..this always show display error message for REAR DOOR OPEN....HOW TO CLEAR THIS ISSUE PLS HELP ME..
Ad
Advertisements
Rear Door has micro switch, which you might slightly re-position to ensure switch closure.
Look for mounting screws that hold switch in place. Loosen screws and re-position.
Alternative:
See if you can activate switch with your fingers. See if error message disappears.
Switch may be defective as well.
Alternative:
THANKS FOR ADVICE....Sir. i cant find micro switch.kindly give location for switch pls...find one door closing side sensor...laserjet pro200 colour m251n
Error message "rear door open" on the printer.
Do a power reset to see if that solves problem.
With printer turned on, disconnect the power cable from the rear printer.
Now disconnect the power cable from the wall outlet.
Wait a minute and reconnect the power cable. Restore power. Is error message gone?
Be sure to use wall outlet. Don't use a power hub or a surge protector.
If you Flip the back door down, you will see two plastic pieces near top.
Are they perhaps broken off. With door closed, tab on the left side goes into a hole to activate door sensor to indicate the door is closed. Sensor switch could also be defective. Replace switch if plastic pieces intact (not broken).
Advise
Advise
Ad
Advertisements
Advise
yes sir .....rear door problem only...rear door sensor closer liver not working properly...it reseated after rear door open message did not come and working good....thanks for your cooperation...THANK YOU...
Ad
Advertisements
