Your Xerox printer error 010-397 denotes a problem with the fuser. The fusers are the core component of the printer which allows the print to stay for a longer time. So, if it is troubling, you will get specific indications like taints or parallel dots on the printed sheets, irritating noise from the gear, excessive heat generation, and others. To get rid of this problem, you will need to Reinstall the Fuser, Reset the Fuser, or Replace the Fuser. Get a complete guide on how to perform these methods at Printer Tales.
