Dear all,
From time to time I buy secondhand printers and now my hands on a Oki ES5430 from the executive series.
This printer comes with a call service 134 error.
After checking visable the LED printheads and the ribbon cable if good inserted a could not see something was wrong.
In the maintain menu it shows all LED printhead gives an error.
Then I try to find if the right printheads are installed.
A few numbers are on each printhead and an internet search don't show that these numbers belong to this printer, the following nummers I found on each LED printhead (4x)
444188 15092827870121300 1400282787
These numbers I don't find on internet.
The LED printhead serial number should be 44317201 LED Head Unit-51TRA
That each printhead is dead I don't believe.
I swapped aswell printheads and same result.
Hope somebody can help me out for which printer are these installed printheads ?
Thx
Thx
