Pixma iP6600D scaling issue
I have had the iP6600D since 2006, and I was using it until two months ago with a 2006 iMac without any issues.
Two months ago I got a Mac-mini (Lion 10.7.4) and all of a sudden there is a scaling issue. I am certain that there was no issue until maybe two weeks ago. The printer is set to 100% in the printer setup dialog, but the actual print is scaled to about 102.6%. I have no idea why this is happening. Since I have to be able to print exactly at 100% scale, I need to find out how to fix this issue.
Any ideas?
I have uninstalled all Canon-related software (that I could find) and installed a new Canon driver through Apple Software update.
The printer will still not print at 100% scale. In the printer setup dialog, 100% is chosen.
Please help!
Now I have installed the Canon driver again, and the problem persists.
The image is 4x6 inches at 600 ppi.
The printer is set to print at 100% at 600 ppi.
The image is a couple percent larger than it should be (ca 6.125 inches wide and proportionally higher).
It's almost as if the Canon printer does not know how long an inch is.
I now believe the scaling problem was due to a corrupt PSD file and not due to a printer problem. The printer is now again printing properly at 100% scale.
