Samsung CLP-500 on linux redhat 9 networking problems
Discussion in 'Samsung' started by Johann, Jun 10, 2004.
  1. Johann
    Johann Guest
    I must say installing the Samsung CLP-500 color laser printer is a
    headache. Appearantly I have to use Samsung's proprietary
    "linux-config" software that comes with the printer. Fine, but now I
    have to access EVERY printer via this program.
    Now I am trying to print remotely and everything seems to work when I
    install and configure "linux-config" but when I send a test page to
    the que all I get is a processing message and nothing else. The que
    has a postscript file on the list but somehow it is not making it to
    the printer.
    with linux-config I tried many various settings to get it to work. The
    one I thought would most likely work was to set the connection of the
    remote printer as a remote LPD with the appropriate host and que name.
    I also tried the IPP configuration where it requires a user and
    password. Still to no avail.
    Any thoughts? Thank you for your time.
    -Johann
    #1
    1. Advertisements
