Forums
New posts
Search forums
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Printer Forums
Printer Repair
Samsung CLP-650ND - Poor Quality Output
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
[QUOTE="lothian, post: 212213, member: 11686"] Our two Samsung CLP-650ND color laser printers are producing awful--and wasteful--output. The quality of both printers was perfectly acceptable until some recent, non-specific event--meaning, I have no idea what is different now vs. before--changed that. Take a look at the image below; this is typical output from both printers. [IMG]http://i1270.photobucket.com/albums/jj608/lothianmcadam/Typical%20CLP-620ND%20Output.jpg[/IMG] Perhaps [B]most[/B] strange thing going on, and something I cannot show in an image: neither printer will output in "draft mode" [B][I]and [/I][/B]when a printer job set to highest quality output is worse. Same for monochrome output (i.e., "greyshade): output is solid black only--no greyshades whatsoever. Additionally, both printers lay heavy toner that is tactile and sometimes doesn't bond to the media consistently. This/these problem(s) seem(s) to be a fuser issue. So I checked the fuser first. I swapped a replacement fuser with no change to output. The printer consumables report lists the fuser, toner, transfer belt and take-up rollers are each significantly within their respective lifespans. Given that 1) the output is consistent across two devices; 2) the problems began at the same time; and, 3) the printer software quality settings are suddenly rendered useless, I suspect (admittedly paranoid) that Samsung has updated driver software to hobble the printer if non-Samsung toner carts are detected. Whatever the cause, we're down to production printers here with no apparent remedy, and we're wasting toner and media. Rather than summarily swap expensive consumables, I prefer to simply identify what is broken based on [I][B]consistently reproducible problem output[/B][/I], which shouldn't be particularly difficult. First things first: anyone recognize the output artifacts in the image I include? What is the cause? Second: any thoughts on the other, software/driver presumption? [/QUOTE]
Verification
Post reply
Forums
Printer Forums
Printer Repair
