Toner problem with Kyocera FS1010
Discussion in 'Kyocera' started by Gerald, Jul 27, 2003.
  1. Gerald
    Gerald Guest
    I have recently bough an FS 1010. I see that cheap toner cartridges
    become available on Ebay (normally about £25). These claim to be
    original and unopened.
    However, having purchased some, I find that the printer does not
    recognise them - the toner empty light stays on even after installing
    the new cartridges.
    The machine is not faulty as my supplier replaced it, and there is the
    same problem with the new one.
    Both machines worked properly when new (full price) cartridges were
    installed.
    Has anyone else met the same problem? Is there a workaround? Or do I
    have to stick with buying the full price expensive ones?
    Comments, help and suggestions will be much appreciated.
    Gerald
    #1
    1. Advertisements
  2. Gerald
    dalewb74
    Feb 5, 2018
    26
    0
    this is an old machine and kyocera can be very picky about you using a genuine product purchased from them.
    dalewb74, Feb 5, 2018
    #2
    1. Advertisements
