White bands across print
Discussion in 'Printers' started by Terry Pinnell, Dec 13, 2003.
  1. I use the inexpensive Lexmark Z23 that came bundled with my PC. It
    usually gives reasonable prints, whether colour or b/w. But it's now
    producing thin white bands across the picture. I've gone through the
    clean nozzles and alignment routines, but still no good. According to
    utility, cartridges still have plenty of ink left.
    What could be cause and how can I try to fix please?
    #1
    1. Advertisements
  2. Terry Pinnell
    Gary Tait Guest
    Some nozzles may be clogged to the point that normal cleaning and
    mantenance will not rectify the problem. Try rapping the cartrinde on
    a table, then try steaming it if that doesn't work.
    Gary Tait, Dec 14, 2003
    #2
    1. Advertisements
