Xerox Workcentre Pro 35 pcl codes
Discussion in 'Xerox' started by Guest, Dec 17, 2004.
  1. Guest
    Guest Guest
    Does anyone have the PCL codes for all trays of the
    Xerox Workcentre Pro 35? I need to print simple dos
    documents to specific trays.
    Please help!! :)
    Guest, Dec 17, 2004
    #1
    1. Advertisements
  2. Guest
    Alan Guest
    A PCL5 reference gives this:
    The Output Bin Selection command selects either of the two output
    paper bins (upper or lower [rear]) for paper output.
    <esc>&l#G
    # = 1 - Upper Output Bin
    2 - Lower (Rear) Output Bin
    Default = Upper Output Bin
    Range = 1, 2
    So try this, and if you have more than two trays, just see what
    happens with # = 3, 4, etc.
    Also you might try the PJL command OUTBIN:
    OUTBIN Sets the default output bin.
    values: UPPER, LOWER,
    OPTIONALOUTPUTBIN1, . . .OPTIONALOUTPUTBIN62
    PJL commands go before and after the PCL of the actual page. Most
    printers that support PCL5 or above can use PJL.
    Alan, Dec 21, 2004
    #2
    1. Advertisements
