How to FORCE factory reset Lexmark B2236DW
I wanted to do the reset using the menu but still SAY 0 page to print red light flashing and it doesn't taje the command anymore .
Maybe there is a phisically way to reset to factory defaults i see others models something lilke keep it pressing some buttons on the printer while is Starting UP
Any info is welcomme Please
With HP, they have a secret button order that brings you to the technicians menu where you can do semi-full resets that are more than factory. Lexmark may have something similar.
From Lexmark:
9.23.7. How to reset to factory settings on Lexmark printers​
  1. Open the printer’s web page and Log in as Administrator.
  2. On the menu select Settings.
  3. Select Device.
  4. Select Restore Factory Defaults.
  5. Select Restore all settings.
  6. Select Start.
    This will restart the printer, restore all printer settings, fax settings, network settings, and app settings to their factory default configurations, and remove all non-standard apps.
  7. Select Start.
    The printer will restart.
  8. Set date and time.
