Hi,
I'm an artist/illustrator looking for a bit of advice on the best A3 scanner and printer. I would ideally like an inkjet printer and it would need to be able to print A4 and A3.
The scanning area needs to be A3 but I would really like it slightly larger as it helps to have a bit of bleed on the image I'm scanning. So if A3 is 420 x 297 mm then it would help to have an extra cm or so either side.
I was looking at the Brother MFC J6510DW but as I said I am an artist and have heard that the print quality on this printer isn't particularly good (and I'd like it to work aswell as it can for images).
Pricewise I'd like something under £400.
This might be asking a lot but any help anyone can give me is greatly appreciated!
Thanks. x
Thanks. x
