Forums
New posts
Search forums
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Printer Forums
Printer Discussion
Epson ET-4850 has more capability than it reports, and that is a problem.
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
[QUOTE="Bobbo, post: 220243, member: 18596"] I have been using PhotoShop Elements (hereafter referred to as PSE) to scan on my twain compliant HP printer scanner. PSE apparently queries the scanner for its max resolution. The HP reports 1200dpi, so PSE allows me to scan in at up to 1200dpi. The new Epson ET-4850 that I just bought has a maximum scanner optical resolution of 2400dpi, and interpolated resolution of 9600dpi. However, the Epson reports to PSE that its maximum resolution is 300dpi, so that is as high as PSE will allow me to scan. I am scanning small photographs and enlarging them, so I need to scan at 600dpi to 1200dpi. I am having to do this in two steps. First I have to use Epson's ScanSmart software to scan in the images and save them to the hard drive. Then, I can use PSE to load the images. It would be much simpler if the printer/scanner would just report to PSE that its maximum resolution was 1200dpi, like the HP did. [/QUOTE]
Verification
Post reply
Forums
Printer Forums
Printer Discussion
