Hi I have not been able to use my HP Photosmart 8250 printer since I loaded Windows 10. HP says the product is no longer supported. Is there a driver out there I can get from anyone?
Hi Peaches, welcome to the forums. You should still be able to use your printer, but you'll need to use the default driver that Windows installs. It should be as simple as plugging it in to your PC and letting it get auto-detected:
