It sounds like you’re looking for a thermal transfer printer that can print number plates to legal specifications. For this kind of task, you’ll need a printer that supports high-quality, durable prints that meet the size requirements (520x111mm) and can handle specialized materials, like reflective film, which is often used for number plates.
Here are a few options to consider:
- Zebra ZT610 – This is a robust thermal transfer printer, known for its high-quality prints. It’s often used for industrial applications and could be a good fit for number plates.
- TSC TTP-2610MT – Another solid thermal transfer option, with a good reputation for quality and durability. It can handle larger label sizes and might work for the number plate dimensions you need.
- Brady BMP61 – Though not the cheapest option, this printer is versatile and could be suitable for printing onto various materials, including those used for number plates.
I would recommend checking if these printers are compatible with your specific number plate material and that they can print at the required resolution for legal compliance.
If you're on a tighter budget, you might also want to explore second-hand options, but make sure to verify the printer's condition and capabilities.
Good luck with your search, and feel free to ask if you need more help!
