Hi,
I am considering getting a new printer and would like opinions on the best brand and model.
I would like:
- All in one printer scanner copier
- It is for light home use only
- I am inclined to go for an inkjet as I assume they are cheaper than laser and my needs are modest.
- Reliability and value are important.
With regard to this last point my existing printer is a HP psc750 and based on its performance I am inclined to completely avoid HP products. While this model is old there are a number of aspects about it I find immensly irritating:
1. For a while now it has randomly been indicating 'Scanner Failure' when I power it on and suggesting I power it off and on again.
2. Recently it stopped printing colour with the error message 'Incorrect colour cartridge installed.' Note that this was a relatively new colour cartridge which printed without issue for a couple of weeks before this started so it is definitely not and incorrect cartridge.
3. The cartridges are ridiculously expensive. I would rather pay the genuine cost of the printer up front and not be ripped off on ink.
4. The 'HP director' software which gives detailed control of all the printer's functions is not available for Windows 7.
I believe that the above problems are largely due to crappy software, I am an engineer and have dismantled much of the printer to see if I can see any physical cause for the above intermittant problems and despite its age I can see no defects and am impressed by the shape it is in.
- So, is my assessment fair? Or might HP have improved their printers' reliability such that a newer model would give reliable perfromance ?
- Are HP replacments still a ripoff for newer models?
- Do all manufacturers use this cheap-hardware-rip-off-ink-refill buisness model ? Or equivalently which brand has the lowest 'total cost of ownership' (to use the current cliché)
- Are there any other factors I should be considering? Given that the print quality of my existing one (when it prints) is adequate I am assuming that the quality (DPI etc) of any modern printer will not be a factor ?
Thanks,
Usjes
I would like:
Thanks,
Usjes
