- Oct 24, 2013
Hy guys, I found this printer on sale and pulled the trigger and bought it. It not the best one one for refilling as I read and it came with 'demo' cartridges and in two weeks of use I'm already half way through the ink. I found some replacement XL cartridges but I was thinking to first try and refill the ones I have now using an InkTek kit that has a support where the cartridge connects and you fill through it without making any holes in the body and risking to damage any HP sensor. I cannot post a link but the kit is called InkTec Refill Kit HPI-7018C and a vendor recommended it and I wanted to ask a second opinion. Will it be ok to use it with these 'demo' cartridges? Is the InkTek ink any good? or is there a better ink out there for hp printers? Any help would be appreciated
