Missing features on WP-4530
I recently bought a new Laptop with Windows 10. Since then I have lost a few feature on my WP-4530 I used frequently with Windows 7 on my older laptop. I can not choose the rear tray and can not find a setting for reversing the print order of multiple page documents. Is there driver to correct this or is this printer not compatible with Windows 10?
Thanks Ruffin,
I had done this before and twice since I had your reply. It goes to the end and tells me it can't find the driver.
Sorry you are having difficulty. I did download the driver twice and works fine for me.
Follow this step by step:
Go to referenced link previous msg.
Insert your operating system by clicking down arrow
Select Windows 10 32 bit
Click Drivers+
Click Printer Driver 1.32
  • 01/03/14
  • 13.36 MB
  • epson15483.exe
Click Download Button (You must tell Download where on your computer to deposit download)
Locate Download on your computer
Click epson 15483.exe to begin install process
One more thought Harry.
You should un-install the driver currently in use. Follow this:
Control panel -> Devices & Printers -> Right Click WP-4530 Icon -> Select Remove Device
Now try installing new printer driver
Thanks ruffin, I'll try that.
