- May 22, 2011
Right now I have a Lexmark S605 multifunction inkjet that is working fine. But like most of my other printers, it will start doing the same thing. I print sporadically, meaning that I will use the printer regularly for a few days, then the printer will set for a few weeks not being used ( 2 or 3 weeks ). This usually results in clogged print heads. On the HP printers I had, this usually resulted in wasted ink if you could not get the print head cleaned. I switched to a cannon with a separate print head from the ink cartridges. That one lasted me longer and I could replace the print head when I couldn't get it clean again. Then the print head was no longer available, so I bought this one I have now.
When the Lexmark is finally un-usable (replacement print heads no longer available), Would a laser printer fare any better? Their prices are getting reasonable now. I don't do photography. The amount of pictures I would want printed, it is more economical for me to take my memory card into a store and use those machines.
So, do the lasers print at the same quality throughout the life of the drum regardless of how frequent or infrequently they are used?
