Several Problems for Espon Printer
Won’t connect to computer thought Wifi and my Wifi signal is poor despite all the other appliances having strong signal status.
Won’t printer correctly despite changing ink, paper, and going thought Maintenance options.
The printer popping several sheets at a time.
Espon Connection doesn’t work
I tried to download the program thought Espon website but doesn’t register.
keeps printer at the same map
You dont indicate printer model or which operating system???
How far away is your printer from router? Long distance = Poor Signal
Utilize several print head cleaning operations (maybe three or four)
Use 24 lb printer paper. Fan your paper
You dont need Epson Connect to connect to your computer.
Epson Workforce WF-3620
Processor Intel Core i3-4350 CPU @ 3.60GHz
RAM - 8GM
64-bit operating system, x64-based processor
Windows 10
Version 1803
OS build 17134.228
