Printer problems!
I have a printer that will not print. It is on the network, it has the right ip address on our network, i cleared the printer que, it has paper in the printer, i set it as the default printer, i have powered it off and back on, restarted the computer, checked and made sure it wasn't being blocked by firewall settings, and it still will not print anything for me. Any ideas?
Assuming it's not a Canon, try creating a local printer post for the same IP address with standard HP printserver settings (9100 RAW) and then change the printer port for your printer to that.
Sometimes telling the computer to communicate with the printer on a basic TCP/IP connection works when the proprietary ports play silly beggars.
