7800 7880 ink comparability
Hi I know there is a chip problem.
But are the inks of 7800 magenta comparability with 7880 vivid magenta?
Cheers if anyone can help.
If you own both, print and find out. This is a unique question that I'm not sure you'll find the answer unless you're able to do it yourself or have someone print the same image as you with their other model printer while you print with the one you own.
