Hello.
I'm looking to replace my Brother MFC-J5320DW. So the main features I need on the new printer are the same as I currently have:
- Multifunction printer
- Can print A3 page size (no need to scan A3, only A4 needed)
- Compact, as an A4 printer
- Scanner has ADF
- Duplex printing (at least for A4)
I'd also prefer a printer with the tank feature that some brands provide (no ink cartridges are used, just a tank refill).
I've looked at two options, which are:
- HP OfficeJet Pro 7720 A3 - Seems cool but it is too large and won't fit the shelf, it's 585mm and the shelf is at most 560mm
- Epson EcoTank ET-15000 - Looks cool but I think that the A3 paper has to be loaded on the back tray. Can't be sure as I couldn't find confirmation anywhere. If so, it won't work because I have another shelf above and a wall behind, and can't put A3 paper up on the back of the printer. Otherwise, this one could be the choice.
Couldn't find any other similar printers.
Any suggestions, please?
- Scanner has ADF
