[SOLVED] Canon IP4500 output tray closed when it's not
Hi there. I stumbled across this problem where my Canon IP4500 printer wouldnt print anything at all, when i came to print something out it was telling me: "Printer output tray is closed please open tray and printing will resume".
This problem is caused by a broken piece of plastic which would normal press the micro-switch that is pressed when the output tray is open. To fix this follow my step by step guide.
Step 1: You will need 3 tools for this job, Small eletrical screwdriver, wire cutters and eletrical tape or solderer.
Step 2: See picture 2, One the side where the power switch is located, using a small electrical screwdriver, carefully lift and slide the small plastic panel into the middle of the printer. Place to one side.
Step 3: See picture 3, As your looking down onto the top of the printer, where circled in picture 3 press and push away from the printer and that part of the silver casing will slightly come away.
Step 4: See picture 4, Turn printer upside down, where circled in picture 4 you need to lift the plastic casing with a small electrical screwdriver and push away from the printer again the silver casing will come away and you will be able to carefully take the whole of that silver side away.
Step 5: See picture 5, This bit is a little tricky now. Where circled in picture 5 get your screwdriver again and under the little plastic lip just above the paper feed button lift and bring forward (two handed job really)to release the two pins. Be very carefull this point not to break anything. Once that front panel comes forward carefully wiggle and lift up, do not pull. Then it will come away.
Step 6: See picture 6, Your now looking at the back of that panel. Towards the bottom of the circuit board you will see two yellow wires going to a switch, (this is the important bit, this will make the printer think that the output tray is always open, thus solving the problem) cut, yes cut, both wires, remove plastic covering/shething exposing the wire. Join the two wires together, you can do with by either just twisting them together and taping up with electrical tape or solder it up, your choice.
Step 7: Yes the final step guys n gals, time to put your printer back together, do this step by step guide in reverse.
This 100% works on my printer and should work fine if you have the same problem.
Lemme know what you think of this guide.
Thanks
Worked for me too
Had this exact same problem with our iP4500 and this seems to have fixed it: I've never tried anything like this before but it was all easy to follow. Thanks!
You are an absolute star! Thanks very much for posting this guide - saved us having to pay £70 to replace what Canon told us was a unrepairable printer!
Thank you!
Your solution worked perfectly, and I just wanted to thank you for such an excellent set of directions with pictures. You, sir, rock.
I thought I would have to buy a new printer, but luckily I found this guide.
Great step-by-step instructions, with helpful pictures. I don't think I would have been able to figure it out myself.
Thanks for posting it!
As the other posts say, this works perfectly.
Thanks a lot as you've saved me a load of money buying a new printer.
The pictures helped no end.
Well done for being bothered to post this!
Hi, Thank you so much for fix to this problem, I had the same problem due to door micro switch not being closed when the door was open, I was going to bypass the yellow wires but tested the swtich and it seems ok, its just not closing, my solution was to put a piece of cable sleeving over the arm of the switch, this makes the arm wider and so makes the switch close, for now it does. This switch is pretty cheap and flimsy so I intent to replace it with a decent one, problem is finding one small enough and modding it to work without changing the switch holder, I have a spare ip4500 that has the open door problem so I can experiment on that and post back here at a later date. This problem never happened with my ip 4300 so I guess Canon cheaped out on switches to save a few pennies.
Mike
Magic instructions - fixed my printer very quickly. Cat jumped on output tray and broke it - will feed cat again now it is fixed.
Thanks
Must be a common problem. Had been looking for a new one. Thanks for saving my money. Very helpful post and pics although I would have thought your printer probs were caused by passive smoking jusdging by the ash. Only teasing - gave up 10 years ago but reminds me of my desk, car dashboard and backdoor step. :D
Hi and tank you very much !!!
Yes, I still have an IP4500 and thanks to you, I can use it more time than expected :D
Luckily I found this topic, thanks God. Awesome step-by-step guide ^^)
Yes, you rock ;)
Thanks
Thanks for posting!
