- Jun 9, 2024
Had the black ink smearing problem so replaced the square ink sponge as well as adding 2cm of tube to allow easy reinstallation of the pad. Turned it back on. All seemed well until I tried to print. Nothing. Goes through motions but no ink on paper. Done all the routines, not that it was giving me problems before I did the repair. Plenty of ink in tanks. Just isn't reaching the print head. Any ideas?
