Epson Photo+ problem
Hi forum, I hope you can help me solve this.
I have installed Epson Photo+, but it can't open my photo albums. It has only '.ptdx' (instead of e.g. 'jpeg' or so).
I'm using a Medion laptop, rather inexpensive and slow. But I'm a patient guy and I'm happy with it.
(Except for this '.ptdx' problem, of course.)
Your help would be greatly appreciated.
Dylan
Thank you, Vinnie. I saw that in the manual. But in my Photo+ all I see is this ETDX as an extention: no jpeg etc.
Vinnie, it's solved. Don't ask me what I did.. I have really no idea, but it works now. And I'm sure your reply must have inspired me somehow. Thanks again.
What the heck? I am unable to print on full label CD/DVD. Epson Photo+ will leave the large center blank. I tried every setting, nothing helps. Anyone has any idea how to fix the issue?
Hey,
Make sure that you have selected the proper label type and size in the software settings, also adjust the label design to cover the entire readable area, and if the issue still continues, consider updating drivers or contacting Epson support.
Showing error >> ( Epson photo+ has stopped working) when i click on Id Card
I'm having the same problem. the searched extension doesn't resolve to individual jpeg items within the folder only to the file itself. there should be the ability to load individual jpeg files ie. searching for/with the .jpeg extension
Certainly! Can you please provide additional details about the issue you're encountering with Epson Photo+? For example, are you facing problems with installation, functionality, or specific errors? Having more information about the issue will enable me to provide a more precise and effective solution.
I have a WF-2860 and am trying to attach to email to my computer. When I scan, a window comes up and has a drop down with which email software or program do I use. I am NOT using Outlook but that is all it has in the drop down. How do I get the email program that I use to be in that list?
Jim
There must be an option to scan the image itself to your computer. Then attach the image file to whichever email service you're using from there.
Anyone here having or have had the same issue: Epson Photo+ not recognizing/following my printer color settings. No matter what adjustments or how i tweak the color settings, Epson Photo+ prints the same - and its off
I use last version od Epson print+ and every print get me error message, printing go to end but why get me error message? Downgrade will be solution. Bad software from Epson. :)
