Lexmark X1270 wont print
Hi all, I imagine you may be aware of this problem as it seems common, so here goes:
Immediately after turning on my PC, I will be able to print one document then any print requests after that and they wont get printed. After the document is printed, I get a message on screen which just hangs there - attachment 'print status'. Normally this goes when print job finishes.
When viewing the print queue, I get a status of 'Deleting - printed'. After deleting this job via stopping print spooler and deleting SPL file (sometimes also SHD file) in system32/spool/PRINTERS, I get a 'error processing command' message at the bottom of the printer print queue pane. When viewing Control Panel/printers, I see that there is still a job outstanding - attachment '1 job' - even though there are no jobs to print.
Tried uninstall and re-install of printer with latest drivers, Tried a new spare comms cable from a different USB port. Tried directly printing to printer, the bi-directional support is enabled. Tried data type as RAW. Nothing solves problem....yet!
Printer does print a test alignment page though. running Vista 32 bit
Thanks in advance
Similar Threads
Lexmark MS621dn - Reset Imaging Unit? 0
lexmark cs510de 0
Lexmark software 0
lexmark paperjam 34.04A 0
Lexmark 912 gone bonkers.. 0
Lexmark ms510dn, changing language 0
HP or Lexmark Laser 1
Lexmark x1270 issues 0
