The ML-1915 is working well but it's a nuisance because I usually want to use the "Toner Saver" setting but every time I have to go into Preferences, Graphics tab, Toner Save area, and select "On". It keeps re-setting itself to "Printer Setting".
Looking at the manual and at the printer I can't see how to change this. I did read that there was a way of pressing the buttons on other similar models (i.e. using the Printer Setting) but this didn't work on the 1915. I'd like to end up with the driver showing me "On" every time I go to print something, unless I then change to "Off" (then later reset to "On").
Anyone cracked this please - specifically on ML-1915
