USB Cable with On/Off switch for Epson Perfection V39 II scanner?
RLM
It is annoying to have to leave the blue led on and the scanner connected. Continually disconnecting the USB cable when not in use is not a good idea. I am having problems finding a cable that will provide power and data transfer for the scanner with an on/off switch. Should be a simple thing to find! The Epson Perfection V39 II scanner uses a Hi-Speed USB 2.0 interface with a USB Micro-B connector. Comments, help? Thank you,
