Direct-to-Film (DTF) printing involves transferring designs directly onto a film and then applying the film onto various surfaces, including fabrics, using a heat press. When it comes to using a heat press for DTF applications on caps or other items, you would typically use a cap press attachment or a specialized cap press machine. Here are some key points to consider:
Cap Press Attachment:
Many heat presses come with interchangeable platens or attachments designed for specific applications, including caps. A cap press attachment typically replaces the flat platen on the heat press with a curved surface to accommodate the shape of a cap.
