- Jul 16, 2020
I am trying to use the front loading setup for the first time and it has been elusive. I am using Epson Hot Press Natural and Epson Print Layout.
I have followed the instructions assuredly multiple times, but the same things keep happening. I load the paper per the video by Epson on
When I go to print document, since I have selected Espon Hot Natural as the paper source, the only Paper Source options are:
Front Fine Art
Front Fine Art Borderless Auto Expand
Roll Paper
Front Poster Board
I select Front Fine Art and Print. Paper loads, then the printer gets a Yellow error banner that says the Rear Door is closed and to open it, but it is already open. If I try to proceed it just says error and will not continue. Meanwhile the driver window (MacOS) says: "Position of front manual feed tray or rear support is invalid" I have gone through the process several times trying to see if there was a hiccup somewhere, but it all seems correct until the error comes up on the printer LCD.
Greatly appreciate tips to solve the issue.
Henry
Front Fine Art
Roll Paper
Front Poster Board
Henry
