- Feb 7, 2023
Delete downloaded files
- On your Android device, open Files by Google .
- At the bottom, tap Clean .
- On the “Delete downloaded files” card, tap Select files.
- Select the files you want to delete.
- At the bottom, tap Delete .
- On the confirmation dialog, tap Delete .
