Hi there,
Complete printing novice here flying blind and utterly confused/bemused.
Hoping one of you wonderful print experts can assist.
I am looking for a machine to print to the below:
The end product will be used as floormat so I need the printer and ink to create a finished product that is:
As a novice the wealth of specs and information out there is immense as I’m sure you know. I seem to be receiving so much conflicting advice from the printing companies I have spoken to.
Some say I’ll need pre and post treatments to seal the ink:
So far I’ve got to the point of knowing I need a Large Format Flatbed UV Printer.
If anyone had any advice on:
I would be forever in your debt!
Thanks
RW
- Material - Memory foam sheets (PVC or Polyurethane)
- Dimensions of up to 210cm x 140cm and 1.6cm thick
- Able to print white
- Robust - ink will not delaminate from the foam
- Waterproof
- Flexible (it will be rolled in transit)
- Child friendly
- No residual ink odor
- Pre printing treatment: Auxiliary Spray (degreasing water)
- Post printing treatment: Polyurethane fixing agent spray
- What printer you recommend
- Suitable inks for this purpose
- Tips on pre and post printing processing
Thanks
RW
