Problems with multifunction copier plz help
Hello!
I have a Lanier (Ricoh) LD120d, it's a huge copier/fax machine with a lan port.
So far I haven't been able to get this puppy to work in my win 7 x64 machine.
You're supposed to have the optional printing addon, I don't have a clue on how that looks like, all I know is that it has a LAN port. So far my research has told me that as long as you have the fax addon you can hook it up to your pc through lan.
But I'm stuck in the lan port part.
I plugged it in to my router and the green confirmation light turns on, but once I check the DHCP client list in my router it doesn't show my copier nor does the copier have an option to change its network settings.
Any help would be appreciated.
