2 X Officejet 4500 reads "Print cartridge(s) missing or not detected : (tri-color, black)."
These cartridges worked some months ago. Since then I've just kept them taped at the bottom with scotch tape.
Both printers tested fine with these back then. What happened after all this time? Do they just die like that or could there be an issue with my printers? Is there any way to revive these cartridges(hp 901). I tried soaking the bottoms in alcohol and cleaning the contacts on them and in the printers. Any ideas? Thanks!
