Does Dye Ink Work In Pigment Printers?
Discussion in 'Ink Cartridges, Toner and Refills' started by James Smith, Mar 14, 2015.
  1. James Smith
    James Smith
    Mar 14, 2015
    0
    I am just wondering if dye inks work in pigment printers. I like refilling ink but i have found that dye ink is much cheaper than pigment ink. I understand that is does not last as long as pigment ink but i am willing to take the risk. I just want to know if it is compatible or if it will break the printer. Thank You!
    Printer Model: HP Office Jet Pro 8610
    #1
    1. Advertisements
