I discovered there is no more ink for my fully functioning Epson pro stylus 7600
Needless to say I'm heartbroken; I've looked online but am having no luck...the cyan is my downfall... I'm hoping for suggestions. I mean I've been printing on this machine for literally 15 years at least. Never had a problem. I had materials stocked so apparently this discontinuing thing all went down and I was oblivious.
Ad
Advertisements
I'm in Canada, and you can still purchase non-OEM carts for the 7600. Keep in mind that the prices you see are CAD, so the price in USD would be a bit less for these.
https://www.123ink.ca/en/c-15689-stylus-pro-7600-pigment
https://www.123ink.ca/en/c-6153-stylus-pro-7600-dye
I am using these on my 7600 (Pigment) and results are fantastic. I did purchase some refillable carts from overseas and expecting those soon, just in case ;)
Hope this helps.
Thank You SO much I'll go check it out. I hate to immediatly hit you with another ? but will my machine accept these inks or are there motherboard shenanigans I have to do?
Ad
Advertisements
I don't see why these wouldn't work. I would just make sure you purchase the correct type of ink for your printer (pigment or dye). It should be labeled when you get them.
