I have a LJ1320 that the ATTENTION light blink as soon as the startup is finished. By the service manual this alarm is caused by a paper jammed, an empty tray or a missfeed. I've chacked and cleaned all the parts where papers could be jammed but I found no trace of paper and the movement of the sensors are OK. I finally installed a tray 3 to make a test and at that point the problem disappear.
Il I removed the tray3, the problem came back.
Does someone have an idea to convinve the printer to work withiut the tray3?
Thank you.
Canactech.
Thank you.
Canactech.
