HP 8500 , Partial Reset, Semi-Full Reset, Full Reset
Dear Experts
I have got few printers that I don't want them and I am looking to do a reset for a learning purpose.
I tried to reset 8500 following the instructions in link below but it is for 8600 not 8500
http://resetprinters.com/how-to-reset-the-hp-officejet-pro-8600-premium-all-in-one-printer/
They categorized resets to 3 different types Partial Rest, Semi-Full Reset, Full Reset
I couldn't make it work,,,,I don't know if I did something wrong or that won't apply to 8500 ??
Thx
Ad
Advertisements
Zillah: Try this
Observe Printer Screen Carefully
You Must See The "RETURN" Key
Press This Key 3 Times
This opens Support menu
If this fails, press it for 4 times.
Ad
Advertisements
Zillah: Is your printer
HP Color LaserJet 8500
or
HP Officejet Pro 8500
or
hp officejet 8500
or
HP-8500
Makes a Difference
Ad
Advertisements
"HP Color LaserJet 8500"
Reset To Factory Settings
Click Menu -> Until Info Menu Shows
Click Item -> Until Config Menu Shows
Click Select -> Print Page
Click Menu -> Until Reset Menu Shows
Click Item -> Until Factory Reset Shows
Click Select -> Factory Settings Restored
Zillah: Hope this helps -> Out of gas
